Brake light sensor malfunction?
BigRobb
Hi guys! I've noticed that the brake light does not reliably light up when the front brake lever is pressed. It lights up just fine when the rear brake is pressed. This leads me to believe that the front brake switch is faulty. Anyone know if this is an easy fix, or if it's under warranty? I have a motodynamic integrated tail light that is only a few months old if this has any bearing on the issue. Thanks for the help in advanced!
BigRobb
That's most likely the issue. I wanted to run it past you guys to see if that was a common issue. I'm just happy the rear switch works so I can still ride :-D
BigRobb
I'll run through and hit all the connectors I can find and see if any are loose first. That hasn't even dawned on me.
alaskanflyboy
Premium Member
