For anyone interested the 02 sensor thread size for FZ6R / XJ6 is m10 and the pitch is 1.25.This is helpful if you are putting on an aftermarket exhaust that dosent have an 02 sensor fitting already installed.
I put the tbr exhaust on with the 02 sensor installed and this is what i found.
-first start will make you smile lol,i ran it for about ten minutes and was popping and blowing flames out of the exhaust.
-an hour later i started it again and some of the popping had gone away and there seemed to be little or no flames while backing off the throttle.Now i can only guess that having the sensor installed it has adjusted the ECU.
-and one other thing,when you are tightening the header nuts they only need to be tightened to 14lbs as per manufacturer spec (TBR) which dosent sound like much but remember their are copper or brass gaskets from factory inside your head which are soft, and your TBR header flanges are alloy and will bend easily if you overtighten them.
