wachikinow
And to you good day!
My '09 FZ6R was laid over and now the front end is a little crooked :/
Worried about the forks, I took the bike to the shop and they confirmed the forks are not bent.
I loosened the axle pinch bolt, axle, brake calipers, fender, lower triple pinch bolts, and stem nut.
I pumped on the handlebars, but it didn't help the alignment at all.
I also tried hitting the tire against a grounded object, but that also didn't help.
Is there something else I forgot to loosen?
Is there another method I should try?
Maybe the forks really are bent But the bike handles like normal.
Please save my life! Thank you in advance!
