sm00thpapa
Just a thought. Is there anyway to take a chain driven sport bike and convert it to a belt driven sportbike? Just wondering if anyone ever got this done or seen it done. Thanks!
I have a Fz6 and my wife has a Buell Blast.
I clean them both.
We ride them to work. Me 25 miles. Her 10.
My chain driven bike has a dirty rim, fender, swing arm, brakes, etc. Everything is a mess back there after 500 miles.
Her belt driven buell is still clean after 500 miles.
that blast is a fun little bike. i took the riders edge course and those are the bikes they used. i hope one day my wife wants to ride so i can get "her" a small bike that i can ride around town... i mean that she can learn on. a blast or a ninja 250 would be so much fun around town.
Chain just seems like a lot of maintenance to clean, lube and adjust tension every 500 miles. And without a rear stand I heard and seen it is a pain in the butt to do.
I will speak for myself and say that I have 11000 miles on my FZ6 and have never had to adjust my chain tension . if you keep your chain properly lubed and cleaned you would be very surprised how you will not have to do it so often . the only time it gets check it but the service guys at my yamaha shop and when I get new tires so about every 7000 miles is when my chain gets adjusted . I do check it when I lube it but rarely to I mess with it
Belts have no driveline lash and are significantly lighter than chains. They actually transfer power better because of this. The zero maintenance is a big plus. Buell got it right and has been using them for years. The only reason sportbikes use chains is that you can change gear ratios much easier.
You will see more bikes use these in these future, they are just better. Check out the BWM F800 ST - belt driven. The Germans have come to their senses.
as far as chain mess. I use maxima chain wax... no mess..... If you have a mess then you are either using just regular lube... lubing way too often... or using way too much!!! You are only supposed to lube once every 800 miles or so.... Only mess on my wheels, swingarm etc is brake dust and regular dust. You don't lube a chain before you ride you do it when you get home.. If the chain is hot it will suck it right up!:thumbup: And as far as adjusting the chain i adjusted mine when it was new after the initial stretch and haven't had to since I am just under 6000 miles right now....
