Which Slip On for R6 Header?
droppedbike
I can't seem to find any information on this, maybe because it's obvious? I have an 01 R6 header and PCV. Does this mean I need to get an R6 slip on? and if so does it have to be for that year?
fazer1
Hey Pandyman, you get a good deal and are they in good shape? Let me know what slip on you go with and how easy the install is.
pandyman
they look ok, cost me $80 aus ~ $60 us$ , I'm away for a week and then i'll have a play- first step is putting the o2 sensor hole in so i don't upset my ecu. I'll double check the output size and let you know for sure. but i'm planning on something like i posted from black widow as i dont want to be too loud.
there's heaps on ebay in the USA which shipping killed for me
pandyman
possibly later on, i need new tyres first so i'll see how it goes with just the exhaust swap.
I'd prefer to keep air pump and o2 sensor if i can.
pandyman
the pump is in the airbox and pumps air into the exhaust to help burn the unburnt fuel in the cat. there are block off plates to cover the holes in the airbox if you remove it.
the O2 (lambda) sensor on my bike is just before the cat where the pipes all join into 1
