cocosrandom
So recently I’ve had this issue hasn’t been going on for long maybe a week or so but hopefully someone can help me out. I talked to a couple people on Facebook just looking for ideas though.
So my bike will usually run somewhere in the 190’s while riding but now even riding at a constant 65 (Cruising) it’s running at 205-207 constantly. I had an exhaust leak and I fixed that but the problem persists. The coolant and the thermostat were changed not even 600 miles ago along with the oil and filter. The fan is kicking on at 212 and dropping the temp down but never below 205 and then it’s just moves right back up.
I went through the service manual and checked the temp sensor as per the instructions and the resistance is almost double what it should be. I followed the instructions down to the letter.
I bought a new one today and I’m waiting for it to come in.
I just wanted to check around and see if anyone else has run into this problem in case the temp sensor doesn’t fix the issue.
2009 FZ6R
Thanks in advance
I apologize if I posted this in the wrong place.
2009 FZ6R
Thanks in advance
