As promised, I'm back with an explanation and charts to show where the ideal shift points are...
It doesn't matter at what RPM the engine makes peak TQ or HP. What matters is at what point the next higher gear will start to cause the bike to accelerate faster than the previous gear.
Acceleration is a direct result of the engine's torque output at any given moment. The torque is multiplied by the reduction ratio of the entire drive train, including the reduction ratio of the currently selected gear. Divide that multiplied torque by the radius of the rear tire, and you've got a linear force. Subtract the force of the drag caused by air resistance at the current speed, and now you've got a net force on the bike. Divide that net force by the mass of the bike + rider, and you've got acceleration.
Using data from the torque curve of a dyno chart, you can create a graph of the bike's acceleration vs. speed for each of the 6 gears:
That data assumes a rider weight of 155lbs and assumes that the FZ6R 's top speed is limited by aerodynamics to 132mph (actual; not indicated). If my top speed assumption is wrong, it would not affect the shift points at all, so don't whine about that
Where the lines intersect, that's when you shift. Rather than just eyeballing it, I actually calculate all the intersections, so I can get exact shift points.
1 -> 2: shift just before redline (11500 rpm?)
2 -> 3: 10660 rpm (I would aim for 10500)
3 -> 4: 10297 rpm (I would aim for 10250)
4 -> 5: 10119 rpm (I would aim for "just over 10000")
5 -> 6: 10055 rpm (I would aim for 10000)
Here's a graph of RPM vs. speed when shifting at the ideal points:
And for fun, I can create charts to compare the maximum acceleration of different bikes if they are all shifted ideally:
Note that this is max theoretical acceleration, assuming that the rear tire does not slip and that the front stays on the ground. That ZX10 probably starts to wheelie at some point under full throttle in 1st gear, so you would have to back off the throttle and not actually reach that max acceleration of 1.2 Gs
