Shifting gears @ RPM to maximize output
J
justBlue
I usually shift my FZ6R at no more then 7-8000 rpm max - to obtain maximum speed output - for a spirited ride:). It seems to me I gain no extra HP going over 8-9000 rpm, even though I'm still not close to redline:confused:. My bike just seems like it wants to blow up when arriving around or over 9000 rpm. Scares me:eek:!
Question I'm trying to educate myself on is: Does the rpm become saturated to the point where you gain no benefit from high rpm's and you need to shift to next gear and climb the mid level rpm level again - gaining the speed that way instead of higher rpm's in lower gears:rolleyes:...?
I'm not a racer by any means, just want optimum experience from the 600cc Philly she has to offer without springing oil leaks:mad:.
Thank you for any kind wisdom and/or knowledge to share with your fellow 6R:)
Go Yamaha Blue!
I believe you will find that peak output is
Power: 76.44 HP (55.8 kW)) @ 10000 RPM
Torque: 59.70 Nm (6.1 kgf-m or 44.0 ft.lbs) @ 6100 RPM
This will only change with modified tuning and gearing...
or even, if you wish to go as far as, cam modification
Don't worry about damaging the engine, they are designed to run high rpm for long durations
Being Japanese she is pretty well bullet proof,
Buzzbomb, Dart and others can attest to their endurance having gotten more than 50k miles out their rides thus far
I've been riding a while, and always lowballed the RPM. I've recently come to my senses.
Check out this graphic:
http://image.sportrider.com/f/27440112/146_0908_18_z+econo_bike_shootout+horsepower_torque_chart.jpg
Notice on the left the nice, smooth HP progression we've got up to 10krpms, where it drops off rapidly. That smoothness is the "tuning" done to the 6R. It's one of the reasons we love her.
Look at the right graphic. A nice strong torque curve up to 4.5krpms, then a dip at 5-5.5k (which is where I used to shift, Doh!) Then an awesome progression to where we peak at about 8000rpm.
Basically it means our horsepower will increase in a pretty nice way almost all the way to redline. Torque can also be easily managed. By that chart, if you shift at 7k to 8k rpms, you'll get the maximum torque the bike can offer when shifting into the next gear.
I can tell you from recent experience, that she jumps in a satisfying way. It's so easy and so smooth. She'll sound like she's winding like mad, and there's some vibration at 6k to 7k (which is why I used to shift too early.) But the way she moves is phenomenal, and she likes it that way. Don't worry. She's made to run on those lines and you won't hurt her.
Man, I'd hate to have to manage that on those other bikes. Those torque lines are just UGLY! It's the tuning again, and also another reason we love our 6Rs.
On a side note, unless your current road speed is going to be really lengthy, keep a gear down from where it feels it should be. That'll keep you well into that power curve.
If it's a lengthy 45 zone without a lot of stops, get on up into fifth. If you're running a long 55mph zone, get into sixth. It'll keep things cooler, you don't need the torque, and it'll improve your gas mileage.
Think of like a standard shift car with a fifth gear. Fifth is good for travel, at speed, to increase fuel economy. You don't pass in fifth. You cruise in fifth.
Same idea.
That all changes if you're running twisties! Then keep her in that sweet spot. 6k to 8k rpms at all times. Hope I helped answer your question. :)
just get a dyno and you'll know for sure! check out local bike shops for open houses, demo days, etc. and they'll sometimes have a free dyno machine there... may not be perfect, but an idea.
http://www.600cc.org/forum/436980-post6.html
I don't know, the torque may flatline at around 8, that kick in the seat, but the bike really does continue to spin up all the way to 11k, and that leaves you set for the next shift to be back in the torque... I rarely ride this way any more... more commute than fun this last year or so... just trying to get ahead of a few bills that got out of control.
and yeah, bullet proof engine!
i think it does take off a little more when you hit 9k and above not that i do it alot. I have moved up shifting from when i first got it, at break in of course your trying to put as little RPM on it as possible and then after break in your still kinda stuck in that mindframe so it took me a while before i raised my shifting points to about 6-7k. At no time do i ever feel its going to "blow up" this is a yamaha man. Run 11.5k rpm for hours i bet.
You guys are making me think I'm riding a bit squidly,
No no I'm sure it is only because I'm running late for where I'm going
I shift at 10k+ :D
What a differnece it makes! shifting @ 9000 rpm
Shifting at higher RPMs, it's like a got a new bike :). Popping out of first @ 9000rms and before leaving 2nd I'm already hitting over 50mph. WOW!! I didn't know that bike had it in it.... Once you get used to it screaming at you like a "raped ape" and you know it's not going to "blow up", it's a blast! I have no justification now of moving to a larger cc bike. I mean, if that don't flip your trigger -then your just plain a** mad!
Not riding like that all the time by no means. But, to know that bad baby is there, puts a smile on your face...:)
Leaves those Mustangs, Camaros and Corvettes sitting there "like a lizard panting on a hot rock".:D
Thanks for sharing your experience with me!
Love my 6R!!
Love my 6R!!
Thats awesome, glad you are enjoying it. We will see in a year or so if a 1000cc doesnt appeal to you :)
im still good with the 6R but if i had unlimited money id probably get a ninja 1k or fz1
I definitely started out shifting relatively low, rarely above 6k, but as I have become a better rider (this is my first bike), I've learned to shift higher. Now I'm generally shifting at 8-10k or sometimes even 11k depending on how spirited I am feeling...
For me, it has been a FANTASTIC bike. By shifting low when I was first learning to ride I could keep the power manageable. Now after owning my bike for almost a year I'm starting to come closer to using everything my bike will give me, and I can say I am CERTAINLY never bored.
Oh, and for any of you worried about damaging your bike, this might give you some insight to how reliable these bikes are: I bought my bike used with what the owner openly admitted to be 66k hard miles (he commuted to work every day on the bike riding hard on LA highways). Because of the extremely high milage I got the bike for a fantastic price ($2300), and it came with extended warranty coverage (unlimited milage, full coverage, even including towing) through January 2016, so I was not too worried about the bike breaking down. I've now put another 4k miles on, so the odometer is now up over 72k miles. In the year I have had the bike it has been the definition of reliability. I have never had it run anything but perfectly.
I have always shifted a little early, especially compared to some of the shift points mentioned here. I generally shift at about 5,000rpm. I have picked up my pace since I put Michelin 2CT series tires, and have found that my spirited pace has occasioned to have me shift at 6,000 or higher. But it just feels wrong to me to rev that high. I like the bike to stay quiet, in 'stealth mode' as it were. But, I have done stupid speeds on this bike, and wound it up to about 9,000. I quit looking at the tach/speedo when I got there...
But what the heck, it doesn't seem to hurt anything other than the gas mileage!
-Slick
-Slick
That was me. For a LOT of years. But my shift points were originally learned in a car. You know, 3.5k rpm or so, and it sounds like it's winding out, so shift. It works.
The difference here is that these bikes don't redline until nearly 11k rpm! The bike feels like it's just too much, until you pass that 6-7k mark, and everything smooths down.
The 6R is made to run like that. Twist the throttle to where you're happy, run it up to 7 or 8k or so, shift, repeat. Or even higher, as others have pointed out.
It still feels weird to me, her screaming like she does. I, too was into "Stealth Mode." Going through the gears, boom boom boom. I still do that.
Only now, I know both worlds. I find that sometimes I like just cruising along in a higher gear, shifting early and just sort of enjoying the ride.
Other times? YaaaaMaaaaaHaaaa! She screams and she jumps and I love it. This bike is so forgiving and so versatile. When we want to be easy we are able to ride that way. When we want to be agressive - we've got that, too!
-Slick
Actually consensus is this bike gets its best gas mileage around 6500-7000 cruising RPM
This bike is a great all arounder, Jack of all trades but master of none.
I've given myself time to work through that one. I can't find a "consensus."
Still it holds true if we're talking about cruising at highway speeds, in sixth gear. That's where the revs will be. We don't have a higher gear, so that's the best we've got.
Unfortunately, fuel economy drops rapidly above 50 to 55mph.
Gas Mileage Tips - Driving More Efficiently
Gas-Saving Tips & Myths | Fuel Economy - Consumer Reports News
Sure it's for cars, but the premise holds true. Sucks. I don't know about anyone else, but I do not do 50 to 55 on the highway. I gotta take the mpg hit on that one.
However, if you're not in a highway situation but still not stopping often, a higher gear equals lower rpm to maintain the same speed. Lower revs means better mpg until you start lugging, then really need to think about what you are doing.
Anyways, you simply don't have turn the throttle as far in fifth gear to maintain 50mph as you would in fourth or third.
One gear up when cruising equals better mpg. One gear down when not cruising equals better torque.
Simplistic yes, but it works for the commute or tour.
Once again, the twisties change everything! Woohoo for the twisties! Give me some, give me some, give me some! Woohoo!
Let me formally apologize for that last paragraph. It's been too long, it is high time to go, I won't be able to for a good long while, and I need me some twisties! :D
Anyway, the rest of the post is relevant. Drop a gear for torque. Get one up for fuel efficiency.
HaHAHAAA! I just realized:
That entire post I made was summed up in the last two sentences. Kind of like a Cliff Notes.
Wouldn't have been nearly as informative, though. Still. LOL
I know what you mean about twisties! I have been working (yeah!) these last two weeks, and haven't ridden the bike at all until today. Work was cancelled due to rain, but it cleared up and I was off to my favorite lunch spot in South Carolina. 88.5 miles, over 70 were twisty. Highway 28 S and back. Great burger, great ride!
-Slick
-Slick
Heck, yeah!
Love my 6R!!
After i bought my bike i got a survey from Yamaha, one of the questions was "what do you like about your new yamaha?" My reply " 2nd gear,12000 rpm 120 kmh" The next question was" is there anything that disappoints you about your new yamaha?" my reply "4 more gears amd i'm already breaking the speed limit". They love to rev. I've done 10 000km in 6 months.
Might be ready fot that 1000cc
I think your right. FZ1 looks good - I can feel the long term burning of more CC.
Did you see that the FZ09 gets same mpg as the FZ6R? 48mpg... FZ1 only gets 38mpg. And, the FZ09 has a "Touring Version" FJ-09? as well, I like! Dual head lights, Wind Shield:) and side case options (i'm sure you've seen). Wonder why the big difference between mpg FZ1 and on FJ-09? But, I think the technology on new FJ/FZ-09's might be the better option. But, the old/new 2015 FZ1 all shiny "Black" look pretty bad though... erhh-choices... Well, my wife will make that call for me... :mad:
Not sure about that Kaw 1000cc... Seems to get good reviews though. And, I believe Kaw comes with a 3 year warranty. WOW!! that's awesome! Looks heavy?
Bigger cc means bike weighs more lbs... Our FZ6R handles awesome in tight places. Pro and cons.
Cheers old chap!
Iv had my XJ6N 2 years ( It was originaly LAMS restricted her in Aus, NOT ANY MORE ) iv put an arrow dark line exhaust on it and thats it.
The bike has never had a tune since stock so it's running realy rich (when restricted the throttle would only turn one third). It's my first road bike, but if had yamahas all my life.
The power curve on this bike is super smooth when you wrap the juice on. The sweet spot for me is between 8.5 to 10k. Under normal comuting i shift at around 5k (default mindset) the bike most of the time feals very buzzy, i believe this is just how they are.
I'm upping the gearing to 3.20 (15t 48t) (stock is 16t 46t fir those that don't know) and chucking it on the dyno. The bike has heaps of power but i want it to be a bit more torquey at the low end (wwhhhheeeeellllliiieeesss). I never go on the hight way so fuel consuption wont be a problem, if need be ill cruise a gear higher.
But my point is (give me feedback) most of our bikes are quite buzzy/Vibratey, unless your flogging them
