BlastOffMike
Hi Everyone,
So I did something really stupid yesterday. I had a new front tire mounted and when I went to reinstall the wheel (my first time doing this) I somehow managed to incorrectly install the left brake caliper. I put it on in such a way that both brake pads were pushed together and the rotor was sitting between the outside of one of the brake pads and the frame or housing of the caliper. Stupid and careless I know!
Before I realized my error, I pulled on the front brake lever and at first it was very soft but after pumping it a few times it built pressure and felt normal.
Now, I did ride a bit (just a bit in the parking lot) before I realized something was very wrong. The first time I applied the front brake, of course it made a grinding noise and felt weak so I immediately stopped and investigated.
I pushed it back to my garage, removed the caliper and installed it correctly. Now I have a very soft lever and the brakes barely engage. Now you're thinking I just need to bleed it. Well, I tried it. I attempted to bleed both calipers. Everything looked OK. I was getting fluid to flow no problem and there were no visible air bubbles in the tubes. I tried a few times on both sides. Pushed out a substantial amount of fluid (while not allowing the reservoir to empty) and at no point did I observe any air bubbles.
I snugged up the bleeder nipple thingies, reinstalled the reservoir cover ensuring that the diaphragm was fully seated and I still have a very soft lever. I'm able to pull it all the way to the grip.
Looking at the pads as I pull and release the lever, I can see them moving on both sides. But again, still the soft lever. Any ideas what else could be wrong? I'm quite confident it's not a matter of air in the lines. The reservoir is topped up with the correct fluid (DOT 4, per the manual).
Any ideas? Did I damage the caliper by applying the brakes with it incorrectly installed? I don't where to go from here. May just have to put my tail between my legs and have it towed to the shop and explain what I did.
Such a bummer because it's a gorgeous weekend here in Buffalo, probably one of the last we'll have for the year. Sorry so long and thanks in advance!
