HillCountryRider
Well, my clutch cable was frayed and I had to replace it. I ordered a new one from my local cycle shop for $26.00. Once I got it I came here for instruction and found none so I will attempt to help as much as I can:
0: Open a bottle of your favorite frosty beverage
1: Remove left fairing
2: Remove clutch lever bolt
3: Disconnect clutch lever from cable
4: Align grooves in adjusting bolt with housing and remove the cable
5: Pry the safety catch UP using a flat-head screwdriver
6: Remove cable end from clutch
7: Remove cable and replace with the new one
8: Install the connector at the clutch and press the safety catch down to secure it.
9: Insert cable into grooves at the lever housing.
10: Reinstall lever and adjust clutch to allow for 2-3 mm of play
