Removing stock oil filter
Verranth
Does anyone have any idea how to remove a banged up oil filter?
I've been trying the screwdriver method without any success...please help me.
Administrator
Staff member
Try an oil filter wrench if it will fit, or try those rubber pads for opening jars in the kitchen.
Or you could scream at it "To go UN-screw itself!" :don'tknow:
That's all I've got for now. lol
Verranth
Thanks.
Needle nose pliers did the trick :thumbup:
2 holes in the front (kinda like the screwdriver method), but modified so that the pliers go int he holes and then twist.
btastarsky
When i changed my oil the first time, i used an old leather belt to twist the filter off. It's an age old mechanics trick that my old man taught me. Just make sure you have someone hold the bike, otherwise you might be changing plastics too.
Verranth
That would have probably been cleaner....oh well. Maybe next time :)
There wont be a next time :D
Tijeras505
I have found the oil filters are always hard to remove on the FZ6R.
I had to get a filter remover that goes on the end of a socket wrench. I got it at Autozone. It fits over the end of the filter and has two metal clamp-like pieces on either side so as you turn it, it clamps harder onto the filter.
Not sure if you're filter is too damaged to use something like this at this point. For next time, get a filter like K&N that has a nut welded onto the end so you can just wrench it off.
angelsneverlose
my first time, it was hard as hell to get off also! mine was bent to shit when i was done! someone torqued it so much, that even after being forced to buy a cap piece with the nut to go over the filter so i could use a small breaker bar... the oil filter actaully started to twist! not by coming lose, but scrunching and twisting (it was that tight!)...
