Rear Brake Fluid Reservoir Spillover
nilsmacq
Asheville, NC
Noob Question: When changing the rear brake pads I was told I need to open the top of the rear brake fluid reservoir to give the fluid some room when I compress the rear brake piston, but when I did the fluid rose until it started spilling out. (that didn't happen in the video i watched) do I need to do that or no?
Also, need to replace the nuts that hold my rear sprocket on. The originals were flanged. Does it matter if the new ones are flanged or or the flange is serated on the new nuts?
