Question about parts compatability between year models
ETX_Ronin
Texas
Hey everyone, I recently decided I would like to change the gearing of my bike a little to gain some low and since I already have to replace the chain. I found a kit that come with all of it but it states that it is for a 2011-17 fz6r and I have an 09. Is there a difference between these or will the front and rear sprockets still fit an 09? Any help would be appreciated. Thank you for your time!
I use JT sprockets and buy them separately from chains.... get a 120 link chain and cut two links off it, may be cheaper that way. That kit sounds a bit pricey, much will depend on the type of chain. Check out RK chains.
The JT catalogue indicates same sprockets '09 thru 2017. Be sure to get the rubber damped front sprocket.
You may just change the rear sprocket size if you want taller gearing. I went with 43 tooth rear. Not sure you can get a 17 tooth front or if it will fit.
Test various gearing combos at Gearing Commander
[/URL]
[/URL]
Thank you for the information, especially about the rubber dampener. I did not know about that
