I knew the lean condition was what's causing the popping. We had the same trouble with my dad's Harley. (Yes it's EFI with a Power Commander) and he had a huge popping issue on deceleration. Imagine a loud popping backfire coming from an open piped 1450cc v-twin. Yes it was loud and annoying. He was able to fix it by richening up the 0 - 2 - 5% cells, but his interface looked very different and I wasn't 100% sure if it worked the same.I'm running late so I cant comment alot but LEAN causes the mixture to not burn sometimes and thats ignited in the exhaust. You can get a pop with a RICH mixture but more than likely its caused by a LEAN condition. The exhaust temps are much higher when youre on the LEAN side of the curve. Youre on the right track by adding fuel in the 0-2-5 range...Just remember more fuel will not hurt the engine...maybe foul plugs but thats it...Too lean and you can hurt the engine...
