Need Help No start from start button on handle.
NolaB
New orleans
Hello, this is my first post in this forum. I own a 2013 Fz6r, I am having an issue where the bike will not start from the actual handlebar switch. The bike will start from connecting both terminals on the starter relay with a metal connection. The bike has a new battery, new starter, and new starter relay. The ignition switch was also changed to take care of a no power issue diagnosed before. I have a little experience with a voltmeter, so I was able to make sure the starter relay was getting power, and all the fuses were good. I also traced the wires from the start switch on the handlebars underneath the air box; both wires are getting power leading up to the start switch. Is there a sure way I can test the start switch located on the handlebars to rule this part out. I am able to provide photos of wiring and work if needed. Thanks in advance for any recommendations.
I think it would be prudent to disassemble the right handlebar switch and clean up the contacts with some contact cleaner..... you can take your multimeter set to resistance/Ohms (maybe it also has a buzzer)..... test leads on either side of the switch, pressing the button should give you an infinite reading and a buzz if the contacts are working..... do this while ignition off of course.
With ignition on, you should have 12V at the blue/white.... the start switch simply grounds the circuit to trigger the relay. If you don't have power there, then your issue is upstream.......
With ignition on you should have 12V on the red/white at the starter relay.
While you're in there, check the kill switch that it's not causing issues, again clean it up.
Check all fuses, especially the fuel injection fuse and ignition fuse.
Do you get a neutral light when in neutral?
no neutral light in neutral, thanks for the wiring advice I’m going to go ahead and get that switch torn apart to test the resistance, and clean the connectors. I made sure to go through the fuses yesterday which all seemed to be working in the main fuse box by the starter relay. I’ve noticed that the clutch switch prong is broken and I wonder if that directly communicates with the neutral sensor not allowing the bike to start. When I get the connectors cleaned I’ll shoot a reply thanks again
I the wiring diagram, there is the Relay Unit, which contains the starter cutoff relay and the FI relay... so the Neutral switch is connected to that and exiting the relay is a wire going to the Neutral light in the cluster. If you test the Neutral switch and it's OK, could be a faulty relay unit, which is not passing on the signal to the cluster......
So let's review a little logic..... if the bike were in gear (no Neutral light), then to start it, one would have to pull the clutch...... so that clutch switch plunger should be fully extended when clutch pulled, or if plunger in, clutch switch is closed for normal operation. Back to why no Neutral light, is it faulty thus thinking it's in gear, and is your clutch switch broken....... lots of knock-off replacements on Amazon if you don't want to spend the bucks on OEM. It's been used on many Yamahas over the years.
Not sure if this will work if you don't have a neutral light..... first ensure it is indeed in neutral/no light...... does the fuel pump run for 2 seconds when you turn on the ignition with kill switch in Run.
Yea the fuel pump does turn on when hitting the kill switch. It seems the start switch screws are stripped from the PO so it becoming a little more time consuming then I thought. Thanks for the clarification on the clutch switch. The bike is definitely in neutral and we can get the bike running by essentially jumping the starter. My brother drives it everyday this way. Considering the price of the clutch switch I might aswell order one as u said. Are you familiar with testing the neutral switch? I’m really thinking it’s this or the handle bar switch is the problem.
This may help. https://www.600riders.com/threads/09-fz6r-no-neutral-light.59917/
How are you jumping the starter..... on the switch side wires or shorting across the battery cable to starter cable (sparky sparky).
If it runs, then the Fuel pump/FI relay would seem to be OK. If screws are stripped on the handlebar switch, jeez, what did the PO screw up inside there........ might be your answer.
Still a mystery about the neutral light, but to verify the starter relay is OK...... (again, how are you jumping it?).... remove the connector, test the resistance between the two terminals where the red/white and the blue/white connect...... you should have a resistance value. If you have no resistance (ie, open trigger coil), that could be an explanation for the start relay not working...... there's also a fuse there, and two solid red power wires coming in (with ignition off if I interpret the wiring diagram correctly), and power in on the red/white with ignition on if the rad fan fuse is OK.
Man, you have been a great help; to answer some questions I have been jumping it via sparky sparky I'm going to get some time to read through the neutral light forum this afternoon. The first thread seemed to be quite interesting. The start relay was changed actually quite recently as we suspected this part was bad, but no to avail. Thanks again for the help and linking the switch for me im going to get that ordered today.
