Need help installing Flush Mount Front Blinkers
r0bot
Anyone done this share some words of advise?? Couldn't get the stock lights off, I saw in another post you just need to twist them, but that didn't work, figured out the wiring part, just need some help with the removal, installation. Pictures would be VERY much appreciated.
Daryl J
J
jtarkany
When you are looking at the diagram note items marked 9 & 18, these are on the inside of the fairing.
You can reach inside from the top and lift the rubber catch on the top of 9 & 18 with a standard screwdriver, once it is lifted up you can reach inside and pull down, they should come right off.
Once these are off there is nothing holding the flasher body on, you can then pull the flasher body straight off from the outside of the fairing with very little resistance.
Hope that helps :).
r0bot
Thanks guys, got them installed last night with your help and some time. Maybe not the fastest install but successful and they look cool.
