Hopefully there's $$$ stuffed in thereThere might be some bags of money or blow stashed in your fuel tank or a dead fish or something in there, stranger things have happened.
Man I was only just able to squeeze that out on road trips,You should get at least 300 km per tank.
Well my consumption rate is similar to others. 300km? Do u sit on 2000rpm all the time?You should get at least 300 km per tank.
This is what I've been doing the last two tanks. I've noticed a 30 mile increase.Light comes on at I think .7 gallon left. Your range all depends on your shifting and how high you keep the rpms. If you ride high rpms your range will drop quite a bit. Keep shifting up when at about 6k and you will see your range go way up. That's what i do for my commuting days.
Sent from my Galaxy S3 using Tapatalk 2.
