Need Help FZ6R 2014 model hard starting and dies when touching the trohotol
Cjbike
I started checking for fuel and removed the pump. I know i replaced it a week ago but want to make sure i didn't miss any thing. I noticed the feul filter is inside the fuel pump housing, i never seen this before. Its a sealed unit so i can't replace the filter but i need to check the condition of the filter before moving to next step. So what i have done is neatly cutting open the bottom of the plastic housing where filter sits, i have never seen a filter so old and damaged. I also noted that the pressure valve does not open. Its rusted closed. I removed the pressure valve and cleaned all the rust and it seems to be properly opening and closing now. I removed the old fuel filter and replaced the plastic bottom. I used my solder to melt the plastic together. I will get a normal in line fuel filter but for now i really want to see if the problem is sorted. I had a call out so was unable to test the bike. Hopefully tomorrow morning i can test and let you know. Thanks for the advice so far.
bigddy263
Yikes, sounds like you opened a can of worms, hope it works out.
Cjbike
After replacing the O ring inside the fuel pump housing she runs great. driven about 4000km after replacing the O ring and no problems so far.
Only thing i realized this morning, every time i switch the bike off and let it sit for about 5minutes then start it up die cluster would reset. Time reset to 01:00 and trip km 0. Its like the battery was disconnected, not sure what could be the problem as i checked the battery terminals tight, battery new and has lot of volts when starting the bike.
SamC_09
Anymore issues with the bike? Bought an ‘09 with 800miles that had been sitting. Took out fuel pump now she won’t stay cranked like a fuel delivery issue. Gonna go through fuel pump again today so just curious how yours is doing.
