I've looked more into this and the shock from the f4i can be put on the fz6r but it isn't really worth it, for the fz6 it is easier to make it fit the video I mentioned from Dave Moss had an fz6r shown but the advice was for the fz6 with the regular shock.
The shock from the CBR 600rr (2007+) is a good fit considering length and spring rate, I'll look more into this when I will go ride with some friends with a 600rr and take some measures to see if the piggyback reservoir can fit.
Also, if the reservoir has space when the shock is fully extended, it won't hit anything as it compresses? And what type of spacers are recommended, at the shock mounts there are a bearing with a bushing, and considering that most shocks don't have the mounts as wide as those on the fz6r wouldn't the bearing make contact with outside elements like water and dust and should I be concerned about spacers rub against the mounts and the shock or impeding the movement of the shock in any way?
I just want a fully adjustable shock to have a working rear suspension and not have change shocks because they lost some of their properties with age and wear, and spend max $150. And because of that those shocks are some of the options I could try.Not sure how dead set you are on an external reservoir shock, but the stock R3 rear shock fits like stock if you pop in the lower spacers from the FZ6R. They have a 16.4 kg/mm spring rate and are like $30 shipped on eBay. I have a bunch of pictures and stuff in my build thread on here.
I'll ask the vendor online for actual eye-to-eye measurements, and other measurements like the one in the picture with the f4i shock to know if it is worthwhile adapting for the fz6r before I buy one. From what I've seen online it would be a good optionYou'll have to rely on trial and error for figuring out fitment unfortunately. Not really any good way to figure out if it'll interfere with anything without just trying to shove it in there.
If you guys want to put any time and effort into this more, I listed some options there, spring rate information about those would be greatly appreciated. I won't look into this more, for now.
The R3 shock if it's $30 then it's a steal, despite the fact I consider it disposable but where I live I don't think I will be able to find it at such prices and from ebay the shipping is expensive. Asking for the case I manage to find a low mileage one for a reasonable price, how did the bike change?
