kochguit
2009 r6 purchased in 2020. Been running great. Month ago engine warning light started coming on and off intermittently; come on at startup, go off at idle. This went on for a couple of weeks. Took it to the Yamaha dealer In Queens, they told me the code indicated the rectifier. I'm have no problems with the mechanical operation of the bike. (I'm reading on this forum that rectifier problems usually manifest in starting problems or problems keeping the engine running.) The bike is running fine. I use it mostly in and around NYC. Then the indicator light then went off for the better part of a couple of weeks. Now it's back on consistently. Is this probably the indicator light itself or am I looking to replace the rectifier? If anyone's had a similar situation or knows what I might be dealing with, I would appreciate the feed back...TIA
