So I bought these off a guy who has a fz6 & those camshafts are his original cams for his bike, I was wondering if I can put those in my fz6r? Like would it sound good or what do I get out of out it?
Hey guys and gals as some of you may know I just recently did the FZ6 cam mod. I wanted to put together a little thread that chronicled the major steps I had to take along with a few little mods I did during the process. This isn't a true DIY which is why I am putting it in the mods section. If...
www.600cc.org
It changes the power band from pulling between 6500 - 10000rpm to being 4000rpm to 11000rpm
That's the ultimate setup! Exhaust cam goes right in with the timing mark. My intake cam in advance about 4 degree. OEM intake lobe center is 105 and 102 degree was good back when I first did it. It was quite flat under 4K RPM so when I bought the 6R back and did the cams mod again I went one more degree. If you slot the cam gear it's about 0.008" per degree. Not as accurate as the degree wheel method but that will get you close enough.
